TwinTurbo.NET: Nissan 300ZX forum - I would run a tranny diagnostics and see what codes you get
keffboyer2000
on May 16, 2008 at 5:27 PM
please check out my symptoms i tried hellllp !!!!!!
posted by dreamchild128
on May 16, 2008 at 01:12 PM
I would also check your throttle possition sensor and make sure it is set at .45 volts at idle and 5.0 volts at wot. I think your transmission shifts, rely on this sensor to shift properly and at the correct rpms.
dreamchild128
13:12:57 05/16/08
you can also clean maf, cas, and ptu connections
gt300zxtt
14:04:34 05/16/08
Re: you can also clean maf, cas, and ptu connections
dreamchild128
14:15:26 05/16/08
follow the fsm in the engine fuel and emission control syste
gt300zxtt
15:42:34 05/16/08
I would run a tranny diagnostics and see what codes you get -
keffboyer2000
17:27:39 05/16/08
You MUST eliminate the TPS as the cause...
Noncon
13:55:23 05/17/08
Ok I will try it (n/m)
dreamchild128
18:22:00 05/18/08
